i have an idea
glamis
instead of useing 50 gallon drums
that take up alot of room(im limited)
and haveing to weld in bungs for drain valves,ext
what about 12 inch ABS
the cap is rounded
the pressure would be well increased the further down you go
and it would take up alot less room.
the fish tank calculator says if i use 12x12x72
that would be about 44 gallons
thats close enoughf for me
justr wondering about cost(cant find it yet)
and if it will stand up to oil,atf,gas,diesel
what do you guys think ???
david
cfdeng7
CT
That's an interesting idea. I don't know if they would hold the pressure long term but I bet they would if they are not affected by oi. You could make a bunch of them and they would take up very little space. Good idea
glamis
update ABS hates gasoline apparently
but PVC is gasoline resistant
having trouble finding info if PVC and wmo are compatible
CSIPSD
Bend, OR
Dave has an idea... Thats scary!
I would stay away from PVC and ABS for your concoctions...
glamis
well 12 inch pvc is 9.02 a foot
kinda expensive
plus im getting conflicting info about iseing pvc
some web sites say it's resistant
others say it will weaken it
wheres christian when you need him
calling rsr911.come in 911
GreasyFingers
I too have limited space and I’m planning on using beer kegs for a gravity filter setup. I have several of them so I should put them to good use. You can get them cheap if not free and they are stainless steel.
