Rudy's 6.4 puller specs?
Athens, IL
although, we tend to run much longer duration to make up for that in comparison:pimp:
Correct, dmax pw and timing is insane compared to a 6.4.
I still believe that running lower a pw on a bigger nozzle will inject faster. it lets you inject the same fuel quicker into the chamber. You can run less timing and make more power. The faster you can get a complete injection sequence the longer it has time to burn in cylinder. Less combustion heat lost through post burn out of cylinder.
