Dual mass flywheel
rat49f6
Vernon,NJ
i took the engine and trans out of a 95 7.3 with zf6
i was expecting to find a dual mass fly wheel but it looks the same as my e99 fly wheel
e99 zf6 flywheel on the right ... zf5 fly wheel on the left from 95 parts truck
honestly dont remember which is which in this pic but they both look the same
sorry for the crappy pic, but they do look identical in person
Sent from my SGH-T889 using Xparent Green Tapatalk 2
rat49f6
Vernon,NJ
Those are my running shoes for the gym... I almost didn't buy them because they were green and white not green and black lol
Parker, TX
I thought the input shafts were larger on the ZF-6's (don't know about the diameter where it goes through the pilot bearing, though. Maybe they are the same there?). Cheers!
rat49f6
Vernon,NJ
Yep the gym ... I'm old and far and still trying to keep up woth younger women so I gotta do something
Not sure about imput shaft size but the splines are def diffrent
Dieselfever
Beaverlick, KY
Someone had installed a solid flywheel in the '95? Very common.
Yes the input shafts are different, ZF 5 speed has 1-1/4" input and the ZF 6 speeds have 1-3/8", both are 10 spline. The pilot on each shaft is the same for both(ZF6 in the 7.3's only), later the input shaft was upgraded on the ZF 6 speeds for the 6.0's and 6.4's to have a larger pilot but still 1-3/8" splines
