Swaan
- Joined
- Mar 19, 2012
- Messages
- 734
- Reaction score
- 0
I take it thats a 467fmw. Not a 486.
X2 on price. In the market for a 38r replacement.
I have the kit with the s366 and it was only like 2200. Plus 800 for the waste gate. Way better than a 38r and bout the same price after bellowed up pipes and turbo
The benefit of the S366, IMO, is that it opens up your options for different turbos if you decide to change things up, vs being stuck with the stock mount setup and the 38R or modded stock turbos.How did you arrive that a s366 is better than a 38r? I almost wanna puke Im laughing so hard.
Edit: Ive heard that. Ive also heard that its because of the supreme durability...which is.why several guys making 500hp blew em to ***k in short order. Because they are "durable". They are cheap, the single advantage.
its the T-4 mount that gives you the options for different turbos..you dont need to buy a S366 to get a mount.. the S366 they are talking about is a turbo..
Do you have the pricing? Just shopping on a build. Can't you buy a t4 mount 38r?
No sh!t Sherlock... but if you buy the S366 you also buy the friggin' T4 mount that it goes on, which opens up your options for turbos in the future. Capiche??? Or do I need to write it in crayon for you?
what does that have to do with durability?? I believe that was the question you was asked and did not answer...i know some have had luck with the 366 but they spent the extra $$$ for a waste gate... thats more $$ then i have in my set up and i didnt need to buy a 366 to have it......The benefit of the S366, IMO, is that it opens up your options for different turbos if you decide to change things up, .
I think his point is if you're currently running small injectors, but plan to go bigger in the future, do you:
-Throw down $1500 for a 38r, then another $3100 for a S468 + T4 mount
or
-Skip the 38r and drop $2200 upfront for a S366 + T4, then $1500 for a S468 when you go bigger.
So they can't make or won't make a T4 setup gtp38r. T4 doesn't mean you can't run reverse rotation.
waste $$ on something you know will give out on you and needs to be trashed??? why not start out with a 468 and run a tighter housing?? when you do go bigger you only need to spend a couple hundred for the housing..
Ever tried putting a LHT nut on a RHT bolt?
Show me a housing that will spool a S468 with 90cc, 135cc, or even 160cc and stock nozzles.
