68mm powermax
speedinpowerstroke
TEXAS
Any one on here running one? whats your set up? hp/tq numbers? I am thinking about getting one for my setup. any thoughts? my turbo i have in my sig i dont like it..
speedinpowerstroke
TEXAS
I was worried about being told that. I really dont want to spend that much because I still need a built trans hmmm I'll wait and see what some other people say.
slc dzl
Riverton, Utah
I have the 68mm and am also running 205/100s it seems to be a great dd setup and I still am able to tow my boat with it. Power wise the highest ive made on the dyno was 598 & fastest ove ran is 13.4 And I think it should be abit stronger on your setup being you have the supporting mods I didnt have and your closer to sea level.
weazel
Elkview WV
I have one running it on stock injectors. I can't complain, and I love the sound
Sent from in a ditch up side down and on fire with the wheels still spinning
weazel
Elkview WV
And it spools well, if you mash it at a stop it shocks the turbo a bit and it will get laggy but the stock one did that too
weazel
Elkview WV
I ran one with 200's. great setup and went 13.0 @ 8000+ lbs. great on the street as a DD as well
Does it clean up good, I want to run 175 or 190's one day
speedinpowerstroke
TEXAS
looking like a will get one they are a good price and bolt right in...... is there a differance between having the batmowheel and not having it?
weazel
Elkview WV
I don't know, I have the stock wheel in it, if you run a batmo in it, let me know how it works
slc dzl
Riverton, Utah
The one I have has the batmo wheel and if I were to do it again I would just run the cast wheel. I see no power gains compared to others running the simlar setup. Save that $400 and put it toward a Apex.
slc dzl
Riverton, Utah
Hey OP if you are interested i am selling the one i have for $1800.
It is the batmo version pm if you want it.
speedinpowerstroke
TEXAS
how many miles on it? little sceptical bout buying a used turbo last time i did that it came covered in soot and oil and was not what they said it was lol
slc dzl
Riverton, Utah
Understandable, im also leary on buyin used parts. on the miles its around 10,000ish cant remember. And its still on that truck so it hasnt been cleaned up.
speedinpowerstroke
TEXAS
My stock turbo siezed up so gonna order the 68mm powermax hope I make at least 600HP and pray I done seize this one or I am screwed
