Down pipe ?
powerstroke451
Colorado
honestly researched this for a while. considering that the 6.7 already comes with a stock 3.5" downpipe everything that I have read shows barely if any power gains at all.. you may notice a slight lower egts depending on how you drive. also don't know if your considering doing this yourself but it is a knucklebuster for sure
onebadf150
New Orleans
I will be purchasing one from SDP for my 6.7l. I have the same downpipe on my 6.4l and I made a noticeable difference.
Ragu9000
theres gotta be some more details on this thing....is it really that easy to get to? how come there are no videos of the DP installed?
nah te 6.4 is easy to cut out, and easy to access, so if the access is the same and not cutting required, shouldnt be a big deal.
jordan572
Do you undo the v band from the bottom of the truck? You can't even see the stock turbo in the 6.7 let alone get the clamp off. You must have to work from the bottom up?
