6.4 cab removal tips
webb06
Seneca, MO
I've pulled my fair share of 6.4 cabs and everytime there are some things that I just hate so ill make a list and if you have a tip or better suggestion throw it out there
- cab bolts, I usually use a handheld propane torch to heat the head and then use a 1/2" drive ratchet to slowly work them out. Takes forever and sometimes the nuts still spin. If they spin I weld them in.
-Power steering reservoir and hoses, I always make a huge mess when I empty this thing
- lower coolant hose, always end up getting showered in coolant
- hoses on front end going to coolers, drip drip drip, gets annoying
SEABEE08FX4
Montgomery TX
I break the cab bolts loose with a ratchet then hit them with an impact, haven't had an issue yet. On the misc hoses I also use assorted sizes of vacuum caps and also hose pliers/clamps to keep from spilling much. 6.4's are pretty easy to pull the cab on compared to the 6.0 .
webb06
Seneca, MO
You've gotten lucky then. I agree with the 6.4 being easier. You don't have to pull any interior pieces unless the cage nuts spin
Big Angry Hillbilly
I cut the heads off the bolts with the torch. Once the cab is up I heat the loctite / cage nut directly. Then wind em
out with vise grips.
It's unfortunate that Ford wants the dealer techs to reuse the bolts now. That's how I did all of them.
mike@haller's
Cheyenne, Wyoming
I have plugs I put in place on all the trans and p/s lines as soon as theyre off. for the lower hose don't seperate it under the truck. lift it up a few inches then take it off the radiator instead. really saves taking a bath in coolant.
webb06
Seneca, MO
Post a picture so I can see what you mean
webb06
Seneca, MO
radiator. you mean lift the cab a few inches and pull the hose off of the radiator right? then it'll just all sit there while the radiator goes up? where can i get an assortment of vacuum caps?
mike@haller's
Cheyenne, Wyoming
yes disconnect it from the radiator and leave it hang while the cab goes up. its high enough the coolant wont dump everywhere. then once cab is up pore it out. you can get caps at parts stores usually or use hoses big enough to go over the lines then plug the other end of the hose with a bolt. makes a cheap disposible plug.
John@Outlaw_Diesel
Pittsboro, IN
We also just pull the coolant hose off the passenger side of the radiator like mike was talking about, keeps from making a mess. We use latex gloves and zip ties on the lines to keep everything from dripping. For the cab bolts we just use the impact and cross our fingers. Lol normally at least have 3 or so break the nut loose, so just have some one else hold the nut while taking the bolt out.
SEABEE08FX4
Montgomery TX
As long as you don't go crazy with the impact you shouldn't have an issue, just trigger bump it till it spins freely. You can use an air ratchet too if you want something thats slower with less force.
webb06
Seneca, MO
You guys must be lucky. Every time I use and impact they spin. No matter which one I use or method of trigger bumping try. Usually my 1/2" snap on impact won't even break them loose
SEABEE08FX4
Montgomery TX
It wont break them loose, our snap on is rated to 7XX something on full tilt and wont do it either. But thats why I use a ratchet first to get them loose then use the impact and bump the trigger till they are spinning freely then full blast till its out.
Cknox121
Augusta GA
Sub'd good info.
About how long does it take to fully remove cab?
