jake brake
oneturboforme
long story short found a super clean 96' 5 speed crew cab in oregon and im trading my 12 in on it.. i have a d-celerator jake sitting on my bench i was given(bench tested worked great) i was figuring hell throw it on the 96 seeing it wont cost me anything.. only issue is it dose have the 35lb spring in it. would this harm the valvetrain of the 7.3? im only going to be using this for short times if at all. thanks guys
oneturboforme
of the truck or the brake? it is a jake (flapper in exhuast housing) us gear makes them they go for about 1400 seems like a soild unit
oneturboforme
woops my bad lol yes exhuast brake then sorry i thought like the turbo ebpv mod would be considered a exhuast brake... anyways any thoughts on if this will work or do i need stiffer springs?
AirFishAutomotive
DELAWARE
Did I miss something. Why are you getting rid of your 12
oneturboforme
man this is a complete derailed thread lol... i got rid of the 12 becuase i traded my 6.4 for the 6.7 and i miss my 6.4 hands down a better truck in my eyes but really dont see a point of having a truck that expensive if i truely dont like it and that gets 13mpg(regens constantly around 150 miles and i drive all highway doing 65-75), so i have been looking for a reg cab 6.4 but havent found the right one yet and this came along and it is a perfect project for me
but back on topic does anyone know if i can run one without upgraded valvesprings
Central CA Foothills
I have one setting waiting to go on the 96 too.
I think the key question is: HOW MUCH BACK PRESSURE OR DRIVE PRESSURE IS SAFE ON STOCK VALVE SPRINGS?
The US gear exhaust brake has basically the same thing as a turbo wastegate to prevent over pressure and engine damage. It also has a port for a back pressure gauge. Once we have actual knowledge of the above, just put a guage in the test port and make sure it doesn't go above the "safe" backpressure.
oneturboforme
That's is correct.. some of the cheaper ones have holes drilled in the flapper to control bp but the us gear has an actual waste gate to control it..... btw mines on and its OK its honestly anoying if your below 2k and flip it on and the felt effects empty our not very impressive
20007.3L
Manchester, NH
have a video of how it sounds?
oneturboforme
If your looking for a sound like a Jake brake don't bother...... better off strait piping and downshifting sounds more like a Jake then this exhaust brake.. makes a super annoying hissing sound when engaged at low rpms and sounds like a jet at higher rpms(which is the only time you actually feel the brake slow your momentum)
