190/75's Stock fuel pump?
weekendwarriorfsw32
Central California
So I am dropping pressure with stock injectors and stock pump to 35 psi at WOT. I now have 190/75's, with a brand new OEM fuel pump and a Regulated Return hold 65psi at WOT? Trying to figure this out while I have the motor out.
windrunner408
No it won't hold 65 psi at WOT. I have 190/100s and with the OEM fuel pump, RR kit, and AD150 my fuel pressure would drop to 50-52 psi. I can only imagine what it would be without the AD150.
Pizza pig
In the Brig (Banned)
MD
de-tuned it will hold pressure, I ran 190/75's with a stock fuel system and shimmed regulator for a while.
strokin6L
Springville NY
It will drop some but not too bad. I ran my 190's with stock pump and it was fine the majority of the time except for when you mash the throttle. I had fuel pressure set at 60psi and it would drop to around 50. I then got a low pressure FASS feeding the stock pump...fuel pressure never dropped at all after that.
speedracer1000
everett, pa
im running warren 190/75s with a billet wheeled pmax and a reg return with a stock pump. last year it was fine it held 60 psi wot on erics extreme street, tried it the other day its down to 28 wot... looks like i need a fuel pump...
weekendwarriorfsw32
Central California
What FASS lift pump are you using, I did a quick look and didn't see it.
Mdub707
Mohawk NY
... I know I'm beating a dead horse again...
but I bet most of you saying it held pressure ok, were reading at the fuel bowl weren't you?
ncdzl
Where is a desired reading taken from?
Mdub707
Mohawk NY
With stock injectors and a race tune, reading fuel pressure at the fuel bowl it shows the same readings you guys are seeing... reading behind the heads it shows dropping to 25psi or less... on an even milder tune.
fordfreak4life
a1000, modified rr ftw
Sent while spinning 18 wheels
Spindrift
Austin, TX
I had this exact setup on the Ex. When I put the truck on the dyno, fuel pressure dropped to zero. That was the last dyno run for that truck...and not too long afterwards, she popped her gaskets.
Mdub707
Mohawk NY
I will do a sump to a fuelab with custom filter setup feeding into the heads. RR is out of the question for me... I think. Though I might copy what PGreenSVT did on the ORG with his regulator in front of the heads.
Realistically... I'm a cheap ***ker, so I'll probably try out the stock 6.4 pump feeding my stock 6.0 pump.
This was with 190's and a stock fuel system?
fordfreak4life
I'm running a fuel system I built with a dozers return I bought and modified, mine regulates the fuel after the heads and returns down the factory suction line
OBS F350
Burlington, IA
I don't even want to know what my fuel pressure drops to LOL I'm only seeing like 3.6 ICP voltage at WOT also :doh:.
Spindrift
Austin, TX
Yes.
TooMuch03
West Bend, WI
I had a stock 6.0 pump feeding 185/70s with a regulated return. held 62psi everywhere. pressure measured at the regulator.
ncdzl
Any benefits of a low pressure feeding a stocker?
Seems like only an a1000 or the like would be less expensive & a proven setup
speedracer1000
everett, pa
id like to know this as well. is the 15 psi from a lift pump enuff to make the stock pump hold up to the fuel demands of the 190s
