biggest rim and tire set up on leveled truck.
teambluemxer
medina ohio
i have a 2003 6.0 4x4 250. leveled i have 285/75 on it now. id like to go to a rim with some back spacing so they stick out a little. whats the biggest i could go rim and tire set up with out rubbing terribly. thanks!
Betarocker
Sea to Sky, BC
Largest tire would be 33" x 12.5". To get them to stick out, look for a 9.5" wide rim with 4.5" back spacing. Rim diameter can be as small as 16" to clear the brakes, and as big as 30" if you want the ghetto look.
teambluemxer
medina ohio
hey thanks man. i just want probably 18s or 20s depends. tires go up the bigger the rim haha
Fall Guy
Montgomery Tx
I'm running 35"X12.5" on 20's on my 01 W/ a leveling kit. I had to slightly trim the corners of the plastic piece on the factory front bumper.
Only problem I have is the rims have 5" backspacing & they rub the leaf springs. (Very irritating)
