6speedsd
Olive Branch, MS
Looked at it sitting in the driveway, desperately needing a bath, trying to work up the energy to get off my ass and go wash it.
Jeremyleggett07
Katy, Tx.
Coolant/oil change..new coolant reservoir.. New thermostat...new tie rods... Drag link... Bilstein 5100 steering dampner...PMF adjustable trac bar...
mandkole
Northwest
stabbed in a brake controller finally...
TXGLASSMAN
Keller Texas
Got my absolute coolant hose installed
Switchback bulbs and relays showed up today and my lights shipped from JD Friday.
first fill up from topping it off when i drove it off the lot... 17.2 hand calculated mpg in stop go traffic and cruise set at 78mph when the road was open on the freeway back to Minnesota for work.. the truck calculated 18.1 mpg.... but who knows how close i had it to the same full mark since its a worse pita then filling up a 7.3...
jimdawg185
Took the traction bars off my Excursion and fabed them to fit on the 6.4. I was so sick of the crappy shifts and obvious axle wrap issues. It is a million times better, even thought they are straight ghetto bars built out of parts laying around the shop and stolen off the Ex.
Mixedbreed
Laramie, Wy
Drove from Vegas to wickenburg az to swap my son with the ex.
Great break in after the turbo and injector work. Every noise had me nervous but it ended up just fine. Working with my tune writer to adjust better to the 100% injectors and turbo wheel. Egt's got toasty unless I was doing 85. Seemed to like that speed. I guess the boost/fuel and piston speed were all happy at that speed and load.
stonepusher
San Antonio
Got mine a tow pig.......kinda, it's the wife's but i can use it :lookaround: got a smokin deal on it $20k......05 Eddie Bauer w/73k miles!
little luke
Union County, Kentucky
Found my starter hanging by the wires under my truck. The big bolt was missing, and the other is sheared off. Used a 3/8 grade 8 bolt to reattach it untill I get time to remove the old bolts
