6.0 aluminum radiator
02POWERSTROKE7.3
Alexandria, IN
windrunner408
As far as I know they did. I didn't think to ask him and he didn't mention it after he got it installed. I do however remember him saying something about him having to modify the rubber mounts at the bottom to get the radiator to sit low enough for the mounts on top to work right. Didn't seem like a big deal. You should hit him up and see what he says. I'd be curious to know. Sorry I can't be of more help.
NoSlow6.0
Muscle Shoals, AL
Seeing as the mishimoto is 760 and that one is in the 250 range I would be kinda leary and the mishimoto has a lifetime warranty and the other says it has a 1 year "promise" I would be afraid I was just throwing money away.
Vanillaant
I guess, we'll see how well it holds up for him (if he posts about it not holding up). I agree though the $250 one does seem to good to be true. The BPD one is only, $352, which would still be better than $760.
madpowerstroke
Mississippi
I have only one problem with the radiator, but I would think any aluminium radiator will give you the same. The radiator will burn skin very fast, so fast that it will give you second degree burns faster than you can say what the F when you skin touches it when hot. Nate is right I had to cut the rubber mounts, was sitting to high but after that no problem. The transmission fittings fit perfect, and I haven't had any cooling problems with the radiator. I actually bought the radiator to give a reveiw of it, the price seemed too good to be true and I figured if it worked then I would past on the info. The bulletproof radiator was going to be the one I was going to get before I found the cheaper one. Not saying that the Mish wouldn't be worth it, but the savings can go towards another mod, which was the electric fans from Quicktricks. For about anyother 150.00 I got both, and so far as been a great set up. I live in Mississippi, near Memphis, temps get about 100-105 so far this summer and haven't had a problem, been running truck at the strip and no problems.
Snake
Flo Rida
Bulletproof Diesel or Mishimoto. Great products and you support the site sponsors
02POWERSTROKE7.3
Alexandria, IN
Ended up ordering a mishimoto radiator. Came in today and quality is top notch. Im glad I spent the extra money. Hope to get it installed this weekend.
Sent from my SCH-I605 using Tapatalk 2
a2elvis
Do you just reuse the trans fittings from your old radiator?
If so how do they seal, is there an o ring inside or does it seal to the outside of the fitting bung?
smoking stroker
newark delaware
I have one from performance radiator. 0 issues so far 225.00 bucks think their prices just went up a little though. Also know 3 guys with 7.3s with aluminum radiators from the same place with no issues as well.
Mishimoto
Glad to see you went with our radiator! Post up some installed pictures when you get a chance. :thumbsup:
