Ec/Sb stock height or lowered post up!!
Strokin6.4
Thinking of dropping my truck back down. Really might go just back to stock hieght but I don't really want it too low. Plus I don't consider it a "race truck" but I feel 35s are hurting me. Not sure if I want to drop back down to a 33x12.50 22 toyo m/t so its the same look just 2" lower. Or 305/45 22 nitto 420s but then ill need to buy another set just for the winter because I do use my truck for hunting. Just looking for input and pics to make my mind up. If I go with 33 12.50 22 I might do a f350 block and stock up front or a 1" level so it still has a little hieght but not too much gap.
Before and after. Plan on keeping the xd810 22x10.
MINK
London,OH
Mink are you on stock height?
Mine is that exact setup but with 305/45 Dynapro ATMs - Kinda wish I would of went with the Toyo M/T myself but I am very happy with the performance of the ATMs.
Strokin6.4
You want some 35x 12.50 toyo? Lol I think I might go stock height with 420s. Then sell my toyos and buy stock winter rims/tires
MINK
London,OH
Trade me plus ill throw in some cash on my atms, you can run them in the winter ;)
3brorce
I just put a 1" block under front coil to level it our with the rear. Wish I would have just put a smaller block in the back instead.
Jonnydime
3" drop in the rear and 1"-1.5" up front with 325/60R18's. I know it's not a ECSB but it is lowered.
Stock front 2.5" drop in the rear with 305/55R20's.
Strokin6.4
What's some of your guys opinions should I drop down to stock? Or do the 35s and leveled look too good too change. I know its kinda a bitch for a lot of passengers to get in with no steps and 35s def had their effect in spooling my single turbo lol
bad12jr
Are the 250 blocks on my 02 the same? I'd be interested in swapping for 4" blocks.
Jeff@Spartan
Georgia
I say bring it down. You'll enjoy the truck more. I did at least.
Ipkyss
I went from stock f250 height. To leveled f350 block leveled on 37s. To leveled f350 with stock wheels and 35s. Then pulled the spacer out of the front with the same 35s. I am right with you on not being able to make my mind up. But now I either need to regear or go to a smaller tire. My truck doesn't like my new gooseneck all that much.
At least changing from where you are to a little lower is a cheap option. I think I am going to try 33s 5.4 springs with a 2" block with the over load and maybe another leaf removed. Mainly just because I have to keep the factory block to use my timbrens.
