OBS steering dampner mount locations?
cowboy_dan
Brownstown, pa
I put the D60 in the truck, and with the swaybar, it's got to be one of the best mods I've ever done for a day-in, day-out improvement.
But, I noticed I'm feeling a lot more of the road in the wheel than with the TTB, and quite a bit more than I'd like. So, I want to put a dampner on. But, I don't know where the brackets go. Could someone with a stock OBS F350 take a few pictures of the dampner and associated brackets and their locations for me?
kadeninabnitt
Martinsville, IN
I can't help with a pic but I can tell you how I mounted mine orielys has a mount kit for around 30 bucks I used it to mount it to the tierod and on my 60 on the passenger side u bolt bracket on the axle there was allready a bolt hole to mount the other side hope that helps
cowboy_dan
Brownstown, pa
Did you use the stock replacement damper?
Tom S
I am also interested in this. The 97 Dana 60 I have has the spot for the stud and rubber bushings on the passenger side spring mount but that is it. Who makes a nice stabilizer that does not rust and look like crap right away.
Tom
cowboy_dan
Brownstown, pa
Tom
Could you post a pic of the mounting hole? I'm not sure my truck has it.
I had to drill holes for the swaybar link mounts since my frame didn't have any.
I got mine through autozone so far so good and its been on there a year ill see if I can get some pics posted
Please!!!
Tom S
I will take a photo for you this afternoon. Hopefully it will not rain so I can sandblast it.
Tom
kadeninabnitt
Martinsville, IN
heres the pics
Tom S
Here are a couple of shots of the mounting hole top and bottom
PsRumors
Cartersville, GA
Check everything for tightness.....I was having a similar problem then changed the shackle bushings and tightened down the track bar and it feels much better.
cowboy_dan
Brownstown, pa
I finally got a dampner put on. It is a Gabriel from autozone. Took a little doing to get it centered so I have full range of steering, but nothing too bad.
I do like this. It took out a lot of the jerking of the wheel going over bumps and potholes. Now my wrists don't hurt after a few railroad crossings. You still feel a little of the movement, but it is much gentler and not near as harsh.
Definitely a good addition to a D60.
Tom S
Dan can you post up some photos and part numbers. Did it include the mounting hardware? I want a line on this in case I want to istall one on mine once I get the Dana 60 in.
cowboy_dan
Brownstown, pa
I had to make my own mount. It wasn't hard. 1/4' plate and a little time made a nice mount.
I used #136 stainless u-bolts from my local True Value hardware store. They were in the plumbing section IIRC. Their stock number 9222430.
Rubberizer undercoating is what I painted the bracket with.
