How-To: Replace OBS Ignition Switch
mjonesjr
Salem, IN
I couldn't find a how-to on replacing the ignition switch in my '97 OBS after the rocker that you turn broke.
First, get yourself a new ignition switch from your local parts store.
Here is a couple part numbers if you wanted to go that route. Note, the price is from O'Reilly Auto Parts.
- Lock Smart w/ 2 Keys P/N: LC61770 ($22.99) (Limited Lifetime Warranty)
- Borg Warner w/ 2 Keys P/N: CS448L ($47.99) (Limited Lifetime Warranty)
- Motorcraft: 1L3A-11582-AC ($75.99) (1 Year Warranty)
Tool Needed:
- Long Pointed Punch
I went with the Lock Smart for a couple reasons. One, it was in stock. Two, it was the cheapest, yet had the same limited lifetime warranty as the Borg Warner part.
The first part of the removal is to turn the key to the RUN position. This allows the pin that keeps the cylinder in place to be pushed up so you can remove the cylinder.
The pin can be accessed through the steering column cover. The picture below shows where the pin is accessed.
This shows the pin and where it is without the column cover on.
Once you have the key in the run position, push the pin in.
Pull the key cylinder straight out.
Here you can see the old cylinder and the new cylinder.
Turn the new cylinder into the run position and slide it into the hole in the steering column.
Cycle the key to the off position, ACC position, and the Run position to verify that it is working properly.
Before:
After:
chromehound
Hastings, NE
It took me longer to find a small enough screwdriver to hit the button than to do the rest of the job. LOLLOL
Estrogen Hostage
Will the newer PATS key fit that? I need to do my pickup and would love to key it the same as my X so I carry one less key around.
mjonesjr
Salem, IN
No the newer PATS ignition will not fit. The PATS ignition switches have a chip in them as well that needs programming.
Estrogen Hostage
I was just wondering if the slot on the cylinder was big enough to allow me to use my existing pats key for my excursion to work in the cylinder if I have the cylinder keyed to fit the excursion key.
mjonesjr
Salem, IN
I thought you were talking about using a PATS ignition switch as well :redspotdance:
It is a bit bigger than the factory. I would say the worst case is you could go to a parts store and look at one to see if it would fit. Worst you can do is say no.
Buffalo444
Laramie, WY
Is this the part people are talking about replacing when they have problems with certain things (i.e. WTS power, accessory power) won't function?
bluedge8
Champlin MN
no, this is the key cylinder, the actual ignition switch is farther down the column and actuated by the key cylinder
cbuttre835
Thank you sir. I have a truck with a faulty ignition right now among other things. Key has to be turned with a particular side towards you and jiggled quite a bit.
Aaaand, the driver door lock won't unlock via key. Time to hunt up a matched set.
Thanks for the info. No longer intimidated by this project!
