What are your egts?
loboost
Idle , cruising, @ wot?
Currently running a 66 with 205/150s and seeing mid 500* @ 60-65 mph @ 1800 rpm but only registering around 1-2psi boost.
However I am running a vgt tune. Will a non vgt tune keep spooled at lower rpm or will boost correlate with fueling?
ODAWG714
Orange*County, CA
175/75
Idle in park 350/390
Idle in gear 420 ish
60-65 mph flat ground 600-650 boost at 3-5psi
Wot from 0-90 mph 1361 36-37 with a 64.7 Barder stage2.5
white07psd
Idle 375-425 cruising at 65mph 800-1000 wot 1300 for as long as i can stay in it. Barder stage 2 with stock fuel
peixinho
Wow those are very close to mine! I am in az and it is usually around 110 degrees outside
75 mph flat ground 725-775 boost at 3-5psi
Wot from 0-90 mph 1400 68mm kc turbo 175/stock
Josh@DirtyDiesels
PA
s472
305/150's
supporting mods...
cruising at 80 around 800-900
WOT 1800-1900 thats on a decent length highway pull
