Urgent 7.3 Fuel Pump Options
Powerstroke Man 6.4
My 7.3 needs a fuel pump. Need to order it by this weekend.
Anybody know a good fuel pump that replace the OE pump?
Was looking at the Walbro pump but isn't rated for diesel fuel. The stock Bosch is out of stock. Any suggestions and feedback on the different replaceable pumps. Thanks in advance.
David N
Eastern NC
If the truck is relatively stock, and doesn't need more fuel, I'd stick with the stock. But get a real Bosch pump. Not a cheap knockoff.
Powerstroke Man 6.4
Get the Bosch...
Agreed, stick with the stock bosch pump
Try riffraff for a pump. He always ships stuff quick
Wow I am glad everyone here can read posts!
... I however do agree a Bosch pump is better but also answering peoples questions is important... Smh
Sent from my iPhone using Tapatalk 2
The bosch pumps are out of stock. Riffraff swamps everybody. The truck is not really stock it has stage 2 160/100% injectors all the good stuff for 450 HP
smoker00
Winnemucca NV.
A good stock pump will feed 160s just fine..
If you want more... I love my A1000 over 4 years... and it feed my Big B's no problm..
64psi..
Baker42
New Mexico
I have jakes OBS fuel system on my 95 stroker. It uses a walbro gsl -392 I use it as my plumbing service truck everyday and also tow. It has not let me down 25000 miles still provides the volume 68 psi all day long.
DocBar
Akron, Ohio
I hope I don't jinx myself, but I've been running a FueLab 4XXX for 3 years and 40+K with absolutely no problems. I'd take that over a Walbro any day.
Powerstroke Man 6.4
I just ordered the Walbro from summit racing pump was $113.00 with a $6.00 fuel line quick connect tool kit and $16.00 2 Day UPS shipping to Hawaii. came out to $136.00. Should be here by Monday any other part I need to install the pump? FFD says all it needs is the fitting on the stock pump other than that will bolt right in is that correct?
mattman347
Readyville TN
You will need the inlet quick connect fitting. You reuse your old fuel pump outlet fitting. The ones we have on out website include the fitting you will need.
if you would have called just about any of our 7.3 vendors, they prolly have everything in stock to swap a walbro!
do you have a pre filter?
