Frankenstein.
imelmo
Finally got the 4th Platinum wheel in and I got say with the new taller and wider Nitto 420s it looks soooo much better
I like how it still has a rake to it. Looks awesome.
Twinturbostroker
El Paso, Tx
That truck is awesome! I hope to have one similar very soon ;)
Btw, I love that ruby red color, I think it would look sick, especially with the platinum wheels!
Yea there was a red platinum F350 DRW with 24" American Force that was just sick, turned every one's heads......only thing that might be an issue will be the door jams if they dont do it right and engine compartment.......not to mention trying to locate a platinum tailgate
6.0 p-stroke
North of San Antonio, Tx
I wonder if you could just find a 11-13 tail gate and add the platinum "bar" to it. Personally I'm not a fan of the platinum tailgates, the only one I've seen that I like so far the "bar" was painted so it didn't stand out as bad.
Twinturbostroker
El Paso, Tx
That's actually not a bad idea.....not to mention WAY cheaper I'm sure
JMart
DFW
The plate is tabbed on there but I am sure you could modify it to work. I think Inmotionjosh was working on an alternative to the platy bar at one point.
JMart
DFW
I did? I don't remember the answer if I got one lol.
I think it has to do with the way the hangar kit repositions the spring perch when the truck is lowered. You can see it in this truck which is still a long bed. So its not the frame cutting causing it.
Twinturbostroker
El Paso, Tx
I'll hit him up......
Julian ive been meaning to ask. why does the rear axle look more forward than center?
Jason pretty much hit it on the head, it has to do with the hangers and the geometry with the way the suspension travels, pretty much in a half circle as it cycles, if it was stock height it would be perfectly center....
Here is a generic example, of the suspension at full droop instead of full compression, notice how the rear tire is way forward
