Throttle Valve delete
Jesse_01
Prince George, BC. Canada
I havent really tore it down to look. Can you ccv it like the 6.4, plug the intake hole and vent the crankcase along the frame rail?
Sent from my SGH-I337M using Tapatalk
Jesse_01
I watch a video of a ccv delete online. I see the mpd kit just deletes that box for $250 and you still have to route that one line in a drip can?
to OP and anyone else. This is what I found when I went in there. This is past the throttle body. Half of the throttle body was caked up like this also. Looking into the manifold was obviously black but not caked on too bad. Cleaned it out with a shop vac and some brake clean.
So I removed the valve, and aired up my tires an extra 5psi. Reset the computer and still says 14.3. truck feels a little better in the pedal.
and Cleaned out
How many miles where on your truck before you cleaned that chit out of it?
live life full throttle....
load it like a box car, drive it like a stock car..
An OEM vehicle will undoubtedly have multiple issues if the throttle valve is removed. This modification should only be performed on a vehicle that is running the correct ECM tuning.
Would your tunes with dpf on allow for the delete of the valve with no codes?
Jesse_01
Here is my truck at 92k
CATDiezel
These are the reasons I delete a truck within the first oil change usually!!!!
Spindrift
Austin, TX
Now I'm confused. Is it the EGR cooler that's causing the throttle body to get dirty or is it the stock CCV...or both?
Mpoage
OKC, OK
Is the hose that goes into the ccv box has suction. Should that be plugged off?
The best thing is to route it to the atmosphere. You can't plug it off because the crank case gasses need to be able to be relieved. If it's plugged it could result in oil leaks or blowing the seals on the turbo.
Jesse_01
That hose that goes from engine to front of the ccv box should be atmosphere pressure? I know there is exhaust pressure coming from the box.
