PCM
reis05
Alexandria KY
Will a pcm out of a late build date 1999 work in an 2002 7.3 as long as they were both stock both autos both 4x4 etc?
Thanks
ToMang07
Mainah!
Thanks
Might work, but probably not. Different years had many different PCM calibrations. You will need one with the same PCM code or have one programmed by a stealership for your truck.
co04cobra
WV
No it won't. 99-01s are interchangeable 02-03s are by themselves.
Powerstroke Man 6.4
Thanks
Nope 02-03 Has CAN communication PCM's 1999-2001 does not. so if you put the 99 PCM in the 02 it most likely wont run or the truck will go crazy. (Shifting Dash etc)
