Frankenstein.
Twinturbostroker
El Paso, Tx
pstk5088
If you don't mind me asking, what shim did you end up with for the right pinion angle? I recently finished putting my DJM kit on, and ended up raising the rear end due to a horrible vibration around 70mph. That is using the supplied shim from DJM, I think it is 4 degrees.
JMart
DFW
I had a 6 degree shim in mine. It took care of my vibration that came up without a shim.
Twinturbostroker
El Paso, Tx
Truck was already dropped when I bought it......but I'll crawl under there this weekend and see what I can figure out for you
