Most power and fastest times with a VGT......
stonepusher
San Antonio
Excellent runs and times.
? For you...are you going to put a cage in it now?
Did the track kick you off until you put a cage in it?
Thanks. Yes a cage will be going in for sure. The track we go too is real laid back, with the diesel vs mustang event going on that night, the track operator was just excited that we were able to put on a good show! We are out there pretty often and TSD is a sponsor for different events at the track through out the year so the track operator is pretty laid back with us.
stonepusher
San Antonio
ready to see pep click off another 10 again tonight!!!! hopefully I can get into the 13's easily
Lol, I would like to see it click off another 10 just so I have a back up time, we ran out of nitrous the last time lol. Just don't blow the tires away at the start, your gonna have to ease into it big time!
Ross@Flyindiesel
Kerrville, Tx
ran decent! not to derail mikes thread but we blew the tires away pretty good a few times but fuel only was a 14.4 with a 2.35 60' which is horrible. with nitrous it did 13.6 but again no traction at the start. should be a lot better once the 4x4 swap is done!
stonepusher
San Antonio
I wish I was there to see you run Ross! Truck def makes power! 107mph is mid to high 12's all day long! Congrats bud!
BlueWaffle
Grapevine, TX
What truck is this?
Redneck6.0L
What tires and rims are you using, that's gonna be your next investment. Street tires on average ford, dodge or chev only hold consistent to 10.5-10.8 after that they just don't hold the hp.
stonepusher
San Antonio
Bringing up this old thread again, with more and more better products coming out are there any new numbers out there? This weekend I'm gonna be going to try and tap that 11.5 motor only. This past weekend at the NHRDA races it did 11.8 on the brakes, but my 1/8th mile was 7.55@90, this was on a smaller tune. Gonna try and do some tune changes and then hit the track. I will keep y'all updated.
imelmo
Well mine is going to TSD in a few weeks and I'll be getting a separate set of more appropriate wheels and tires for the track so we'll see. Hoping to have it done in early June so I can demolish all the ricers at the Scrapin' the Coast drags. :D
Ross@Flyindiesel
Kerrville, Tx
well to jump back to where I was mike saw this as well but since we did the 4x4 swap, 240/125 injectors from holders and wills turbo off his truck which is a barder 68 mine did 12.7 on fuel with the stock trans hating life. I know mike has 11.5's in his truck too by the way it was running at the end of the weekend. mike is still also on stock hpop and a single vgt barder which is highly impressive!
Redneck6.0L
A good set of hybrids and a stock pump make huge power. Best I ever did with a stock 05 pump and 340cc hybrids was 10.56@133 that was on nos. But just showing that stock oil with good hybrids do run stong. Matt ran 10.8 on fuel with stock oil and hybrids.
Glad she's running strong for you. Are you coming up to Colorado for the nhrda event end of may
stonepusher
San Antonio
Thanks Shawn, we are gonna push the Vgt as far as we can and then it will be onto big boy stuff lol. Unfortunately I won't be able to make that event, I will be at work. I can't wait to join that 10 sec fuel only club! :rockon:
stonepusher
San Antonio
Well finally got it to the track for some good runs, ran a best of [email protected] on fuel and [email protected] on one stage of nitrous. Not sure quite what happened on the ET but i was running a heads up race with a cummins and he ran a 10.80@124, but I won the race, first to the finish line. Calculator puts it 914hp to the wheels, not bad for a Vgt. I think this turbo is about tapped on air, time to grow up and run with the big boys.
