'76mm Tow power-X ???
B585Ford
WV
Thanks Wayne. I was planning to do a drop in 59 VGT with a BB 76....guess that idea is shot. I get what you, JD, and some of the others are saying with the HP Juniors, but I can't a BB turbo out of my head. I am looking forward to the results of the Holder 73.
Wayne
Twin Falls, Idaho
Ball bearing is fantastic, I just couldn't personally justify the price gap for nearly equal performance. It sounds like you want exactly what the tow-x kit is. it's a great setup, and I'm sure you'll love it if you go that route. I do get the reliability, and improved response aspects though... as well as sound :D It is also more difficult to work on due to more, larger parts under the hood. :( Adding that casting really makes it difficult to pull turbos.
B585Ford
WV
You nailed on the head as to why I have always dreamed of a BB turbo....especially since I have a gear jammer and have a hot shot business on the side....not to mention turbo whistle is the ultimate aphrodisiac LOLLOL
webb06
Seneca, MO
That ain't no joke...even with the cab off its a pain getting them stabbed and the bolts started. I can't imagine doing it cab on
B585Ford
WV
Well if I go that route, hopefully they will never need removed....after all you went through with cracked blocks, I am sure you could do it in your sleep now.
08BIGRIG
WI
I put the entire High Power Kit on cab on. Wastegating and all. :pimp:
I may have said :wtf: a few times along the way.
Wayne
Twin Falls, Idaho
That's pretty much exactly what I did on Erik's truck the night before DPC '12. Turbos blew at 4:30 in the afternoon. Swapped them cab-on, and had it rolling by about 1 the morning of DPC. It's not fun. knuckles were bleeding, forearms were itchy with firewall insulation, but it got done.
08BIGRIG
WI
I totally know what you mean Wayne. I bet that was as fun as jerking off with a fist full of razor blades. :doh:
Wayne
Twin Falls, Idaho
code3f250
What exactly Is the difference in the tow power x vs the jr high power they are both 76mm. Is it sounds and efficiency due to the ball bearings?
bft blue oval boys
Burlington, NC
What kind of power are High Power's capable of? Any chance of a CCSB getting close to the 11's in 1/4 mile with them? On fuel only
Sent from a Cummins plant, driving a TDI, wishing it was a Powerstroke
04stroker
Sarasota-Bradenton, Florida
For those of you talking of swapping turbos can on screw that! LOL I have done it and is a royal PITA. If you have access to a lift I would lift the cab every time to do turbos. Much faster for me anyway.
jdgleason
Fort Collins, CO
The precision 76 and stock housing 76 are quite a bit different. They use the same compressor wheel, but different housings, center section, and turbine.
