P1282 P1211 at WOT?
Powerstroke Man 6.4
So I did a WOT from a stop to 120 MPH and got these codes P1282 and P1211 on Dave's (Swamps) 200% N drag tune.
P1282 is excessive ICP
So i'm guessing the IPR is 65% (WO) to try to keep up?
P1211 is above or below desired
P1211 im guessing the HPOP cant keep up?
Powerstroke Man 6.4
I guess I shouldn't worry about then? All I can say is wow Dave does excellent tuning!!
I got 160/100% (Swamps) TE-T500 and Dave's 200% N tunes this run was on the Drag tune. and more stuff I guess the ole T-500 cant keep up
Justin@DP-Tuner
I would look into the IPR and it's wiring. It may be stuck or grounded. The P1282 means excessive pressure, which would mean the opposite of calling for 65% duty cycle. The P1211 just means ICP is out of range (high or low).
Powerstroke Man 6.4
Possibly but those codes only pop up if I do a WOT. regular driving no ICP codes.
bruce
Middle east
the poppets in the injectors could be floatin, the o-rings could be torn, the tune could be callin for too much pw, the ipr wiring could be funky, or the pump could be lazy
Powerstroke Man 6.4
Do you have a way to watch ICP and IPR duty cycle?
I got my dashdaq
Im thinkin the pump is a little bit lazy and cant keep up. Maybe have a excuse to preorder a honey badger SR or a buy swamps gen 3.
Powerstroke Man 6.4
Do a WOT run while monitoring those two parameters with your Dashdaq. See what kind of values they are showing.
The only thing is I cant monitor IPR DC I only cant monitor ICP but its in a weird "mega value" do you know how to change that ICP "Mega Value" to say PSI ?
