Utilizing High speed on Fuel Lab?
PTSUPERD
Any of you guys who are running these two speed pump have them wired to where they go to high under a set boost pressure? Im dropping fuel pressure at WOT. Not a dangerous drop, but probably enough...
Thinking a type of switch like is used with two stage water injection setups....
kyle43335
In the Brig (Banned)
use a pressure swith set to 15-20 psi that activates a relay that switches the speed control from ground to 12+
done
Pizza pig
MD
same pump I run, needle doesnt move from 60psi with 225s. Hmmmm
kyle43335
225 100s and mine doesnt move on the slow speed.
you dont have a jj rr do you? lmfao
kyle43335
uhhhhh. lol.
Where do I need to look first?
post up what components your system has (filter numbers, line sizes,sump or draw straw, etc)
main feed should be no smaller them -8 with sump.-10 with draw straw. after the y it should be no smaller then -6 with a -6 return line, if its all custom.
also post what make and model your regulator is. whats your pressure set to?
co04cobra
WV
I have a fuel lab on my 00 truck that is like the other guys. 300/200s and it never drops any pressure.
There is an old AD in front of mine though, if that matters. Are you running a lift pump?
PTSUPERD
I'd have to find all that out.
Drawn from a sump.
Pics of return here:
http://powerstrokearmy.com/forums/showthread.php?t=18249&page=10
Here is my pump and filter setup. Dont hate on my hose surplus. lol
