Transmission slipping already?!
Pwrcummins
I have 102771.3 miles on my truck. I have an SCT tuner with innovative diesel aggressive street tune. I'm pretty easy on the truck except for about a couple times a week I get on it to keep things smooth with the turbo. Today when I put it into drive or reverse it takes about 5 sec to engage. It doesn't do it every time I go into gear but happens a lot. Also when I'm driving, if I start going from a dead stop it acts like its in neutral then slams into gear. Again it's intermittent. Could this be the last days of my transmission solenoid or the torque converter be going?
fordboy11
Conneaut Lake, PA
This happened to mine and it ended up a seal in my pump went south.
Also put it in neutral and rev it up a little that should help with the pressure and go right into gear.
Pwrcummins
Returned it back to stock and just shifted from drive to reverse to park etc. it did it going from park to drive a couple if times.
Atsah
Maine
Drive it around a bit so that that trans goes through the relearn process..
swinky
Eastern, Nc
Put an aftermarket dd solenoid in it. I doubt it's the Tc.
Sent from my SM-T210R using Tapatalk
swinky
Eastern, Nc
Steve. Powerstroked162 or some gay chit like that is his user name.
Pwrcummins
Lol. I drove it a min ago on stock and felt fine. I'll put the tune back on it tomorrow and see if it acts up again
04cr450
harford county, maryland
I had this problem with my tranny. Turned out to be the line pressure control solenoid... Its not the modified dd solenoid(I replaced that and did not help)... There is a tsb that ford sent out about these symptoms, hence the reason I changed it.
Atsah
Maine
This could very well be the problem OP, that's why I asked if the problem persist with stock tuning.. Your line pressure soleniod could be a little week and the added pressure from the tuning is probably causing your problem..
Pwrcummins
Drove it more and it acts the same as with tuning. Should I start by replacing the solenoid?
Mark Kovalsky
SE Florida, USA
sizeimage.php
[/IMG]
