Tightened up my exhaust, again, that keeps trying to fall off, again. Anyone got any tips to keep it from working its way apart? Flopro 5 inch.
drill a 1/8" hole thru each band clamp/inside pipe/outside pipe and fire a pop rivet in once you have the tailpipe set where you want it. it wont move after that and if you have to remove the exhaust or make any adjustments, a small cold chisel is all you need.
JrStroker
Ahead of the competition
Not a bad idea. Nor is welding it. Gonna see how long it last this time.
Also installed my new pitman arm today. 8 foot cheater bar and my 240lb a$$ pulling on it should have it dialed in tight. But my steering wheel is crooked now. Gonna have to mess with the drag link tomorrow.
Joshbaker
Virginia beach, va
pulled all the emergency lighting off the grill and rear bumper yesterday and cleaned up some wiring that was done in a hurry. found out the chome on the grill is starting to peel. trying to decide what to do about that.
NY_Mott
The Real "OC" NY
Installed the Weather Tech rain guards while waiting on GEICO to look at the truck.
Left rear quarter was backed into.
Sent from my DROID RAZR using Tapatalk
RedRice589
Ocala, Florida
Deleted the stripper pole. Probably not the most popular mod but the damn thing was always in the way.
I think it is a great idea! I've seen the normal tailgate cover instead of diamond plate. But however you cover it up works great! If you want a stripper pole stick one in the B&W hole and G2G!!
Pwrcummins
Added procomp light bar only has three tabs. What looks better lights up or down?
