Wicked wheel 2
tampa_steve
None round factory compressor wheel.
Interested in the surge comment also? Sure your not hearing the waste gate opening?
Are there two sharper points on that wheel?
I just looked on the web and not Tapatalk and he has a 7.3... must have gotten confused.
tshoey33
Danielsville PA
If you want to make it do it (idk what you would) but put it in 4x4 and go to do a boosted launch. Instead of launching just let off the throttle.... it should do it then.
Only do it if you dont mind beating your truck though....
backwoodsboy
Merica
I'd consider that to be bark, not surge.
I have never had surge with mine even towing the big 5th wheel
Same here.
Thats not surge. Thats bark or backlash so to speek.
mattymx
Big Bear, ca
I'm plenty familiar with surge from my Excursion. If driving my mountain road and the truck doesn't down shift on some of the slow uphill corners and I roll into the throttle it surges. Worse than my Excursion did.
c.jank
Houston, TX
Id like to keep the thread on topic and see how many 6.7s with this wicked wheel actually benefit with no BOOM
Thats messed up. But I guess I have the stock air box intact and can barely hear the turbo.
Back to this pic. Is that somewhat of a point at 2 o'clock and 5:30ish?
TrickTruck
Simpsonville, SC
I had terrible turbo surge under light throttle (what I would call oscillation) when I ran the KEM tunes. I did apply more pressure to the spring, but that did nothing. Getting rid of the KEM tunes fixed it for me.
Sounds like the mods need to move this surge issue stuff into its own thread... id like to keep reading about it but no need to muck up this thread anymore.
