will a super duty oil cooler fit on an obs?
ghohouston
Lewisville,Texas
Long story short, the 97 I just bought needs the oil cooler o rings replaced on it (oil in the coolant), and I have a junk motor from an 2002 sitting at my fathers house. I'm thinking it would be quicker for me to get the 2002 cooler all cleaned up and new o rings installed on it, then I can go straight to the 97, drain coolant and oil, and just install the good to go cooler. Time is an issue here, I will have to do this at work on my breaks to get the truck driveable again. So will my plan work or is there anything physically different between an obs and sd oil cooler?
Strokersace
Towanda, KS
Yes, they're the same. I have a rebuilt one for sale. Can't remember what I had it for sale for, I'll have to look.
JCart
Kamloops, British Columbia Canada
As a suggestion I only use stock parts for the cooler and especially the cooler to block aluminium gaskets. Tried an IH set once and they didn't fit just right on the front and leaked so I over tightened the front bolts and cracked the front engine cover.... you don't wanna go there. I always make sure I put the same bolts in the same holes they came out of too.
If you use a ratchet strap to pull the ends on the cooler upon assembly it works good too, and I also use a small nylon webbing strap to hold it all together when installing (so the ends don't pop off when you are wrestling it in place) then just undo the strap when you have the bolt in and started.
cheers,
jrc
ghohouston
Lewisville,Texas
Sorry didn't mean to come across as a dick weed.... I was just so fawkin pissed when I cracked the housing, using corn binder parts and not knowing any better at the time.
j
You're good man, I didn't take it that way. And hell, I have a spare front cover in my tool box if worst came to worst lol
m j
BC Canada Eh!
I tried the ratchet strap idea, and the balancing my 215# on it, to get the orings seated...end result I walked over to the press and popped them on with no drama.
the hard part is installing it in the truck
ghohouston
Lewisville,Texas
We have a press at work I will be using
old man dave
Petaluma, CA
I didn't have any problem using a ratchet strap, but maybe I'm just a better man than you are and work smarter.
superduty4x4
Newport, WA
When I did mine I just greased up the o-rings good and pushed it together by setting one end on the ground and using a short piece of 1x4" to push on... no issues.
ghohouston
Lewisville,Texas
Well it took some doing, but I got it done this afternoon. Ran into issues with the end of the oil cooler that bolts to the front cover getting caught between the crossmember and exhaust manifold. Much harder than a super duty
gnxtc2
Bergen County, NJ USA
jrc
x2 on the International gasket for the front/timing cover. Oil would seep out slightly and start dripping. Had to drain the coolant, drain the block oil gallery and able to sneak out the gasket. Went with the Ford aluminum gasket instead of the black Int'l gasket.
I didn't crank on the bolts fearing that I might crack the front cover. I torqued the bolts to spec.
Billy T.
[email protected]
JCart
Billy T.
[email protected]
Totally Billy torque wrench is the way to go and a good point I neglected to mention. I cracked the engine cover a few years ago now and at the time had the drip drip you noted (after IH install) and of course not understanding the implication and using the notion, a little is good lots should be better..... Not a good strategy!
