Lifters
mcdaniel1991
Germany
I can not find any write ups or pictures of replacing the lifters. Am i biting of too much by attempting to replace these, I consider myself a decent mechanic. I just need more info so i can visualize what i will be doing.
mcdaniel1991
Germany
Ok can anyone give me pictures or a good description of how to get them out? I bought 4 of 8C3Z6C329B. Also is there a certian way to put them back in? I will make sure the damper locating dowel notch is in the 6 o'clock position and then rotate the engine a few times before putting the injectors in.
loboost
With the heads off, unbolt the plastic hold down...I wanna say its a 10mmbolt, and lift them out. Its easy as can be. You'll see if clearly once you're looking at them
sent while driving recklessly
mcdaniel1991
Germany
Alright I'll just have to wait until I'm in there I guess. Thanks
Sent from my GT-I9305 using Tapatalk
loboost
Kinda hard too see but the shiny bolt above the front 2 cylinders is the hold down.
It'll make sense when you're looking at it.
DZL JIM
North East Ohio
Really surprised nobody pointed out the engine needs to be out to do this since the hpop branch tubes need to come off and rear cover needs to come off to do this.
:doh:
