My 86 Fummins Project
Matt_P
Lima, OH
Made some more progress today:
Cam retainer and new oil pump installed:
Destroked adapter plate installed
Flywheel and clutch installed
Engine in the air
Drivetrain in the air
Drivetrain in
Im gonna go ahead and make a whole new crossmember out of round tube and then I can get the driveline angle down 3 degrees and get the drivetrain centered perfect. Then get the rear driveshaft shortened and the front lengthened. Dont mind how nasty everything looks right now, everything is just getting mocked up and then it will all be torn back down and painted.
Matt_P
Lima, OH
No really exciting updates right now. Just got the drive train situated perfectly in the truck as far as driveline angles and sitting within 1 degree of level side to side. Monday will be building the new crossmember.
All new lights for the truck did show up though
Matt_P
Lima, OH
My buddy and I got the new crossmember built today. Im really happy with how it turned out.
Plates cut out on the plasma table
Square tubing tacked in
Getting the fitment right
Finished Product
Now the cab is ready to set on to start mocking up piping and everything. Goal is to have everything mocked up and tore back down by february 24th since thats when I scheduled to body to be blasted.
My A-1000 and regulator should be here tomorrow so I can start building the fuel system
Matt_P
Lima, OH
Picked up my aeromotive A1000 tonight and regulator. Just need to get filter bases and fittings and start building the fuel system next week
Matt_P
Lima, OH
Coming along nicely!
Thanks! Its starting to get closer, picked up my rocker bridges from the machine shop today, dropped the driveshafts off to get lengthened/shortened. Got the vacuum pump resealed. Gotta clean out the oil/coolant mixture from the governor housing of the p pump tomorrow and put my 191 delivery valves in.
Also order my manually adjusting proportioning valve and an ass load of fittings today to build my fuel system and oil supply lines for the p pump, vacuum pump and turbo.
95-SimpsonOBS
Pasco Wa
Thank you!
Its gonna be two tone now, still gonna be tuxedo black metallic on top then dark charcoal grey metallic in the center and tuxedo black metallic on the bottom
That will look good. What wheel/tire combo are you thinking of going with to match that?
Matt_P
Lima, OH
Did some work on the p pump today. The guy I bought the pump from failed to mention that a mixture of coolant and oil went through the governor housing so it was a little bit of a mess. So today I pulled off the governor housing cover and cleaned out the fuel side of the pump as well. I also installed the 191 delivery valves that I traded for the full cuts that were in the pump.
Before cleaning
Cleaned up
Dont mind the ugly green paint, that will be coming off very soon
Also got a big package of fittings today so I can start building my fuel system and other oil feed lines, also got the manual proportioning valve. My filter bases should be in tomorrow
