I need a new one of these
stevens6.7
Houston
Doing my EGR delete and friend ended rounding this off. Isn't this the EGT probe? Any one know the ford part number? Thanks.
Powerstroked162
On Da Juice
Wa. State
Steven, also just so you know, you'll need to drill and tap the probe plate I sent for 1/4" if you plan to use the factory exhaust sensor. Otherwise, a 1/8npt pyrometer will be what you need
stevens6.7
Houston
You don't use that for an egt sensor when doing the deletes. You use an egt sensor from the dpf
Does it matter which sensor?
Is it necessary to actually use a pyrometer right now since I don't tow anything? Does it matter where I drill and tap on the plate?
Dalton_H
Any of them out of the exhaust should work. I used the one that came out the easiest.
Administrator
no, its the longer ones, and iirc there's 2 of them in there. the shorter one reads backward.
WHY NOT
Carlyle IL
The one that got rounded off is no big deal, I tired to use that one at first and at idle I had like 2000* EGT's. removed that sensor and used one from the DPF and it works great
Administrator
yeah it was reading backward.
