sunrisefordparts
I believe this what I will need to do a cab head gasket job on my 08 6.4, 8EA47463 is the VIN#. A quote shipped to 54904 would be appreciated. Will order this week.
If I missed anything, add it to the list. better to have extra than not enough.
qty part number
1 8C3Z-6079-D valve grind gasket kit
6 W712878-S439 Body Bolt(CREW CAB ONLY)
2 W712879-S439 Body Bolt(CREW CAB ONLY)
1 8C3Z-9T514-C Turbocharger Seal Kit
1 7C3Z-6L612-B Turbo Outlet Gasket
2 8C3Z-6N640-A Exhaust Gasket
2 8C3Z-6N640-B Exhaust Gasket
4 W302870B Fuel Line Washers
5 1817957-C1 Exhaust Pipe Bolts
6 W302494 Exhaust Pipe Nuts
2 W300003 EGR-OC Bracket Bolts
1 W711484S439 Intermediate steering shaft bolt
2 388898.S Nylon Washers (Hydro Boost Lines)
3 W302674 Push Nuts (glow plug module heat shield)
heres your quote, i added exhaust manifold gaskets as they dont come in the valve grind kit and took off turbo seal kit which comes in the valve grind kit. everything else seems pretty cut and dry
  • q314955.pdf
duddy
sloshkosh wi
Deal, what is the correct way to pay. Paypal and put the quote number and contact in the info box? Screw it I will just call.
placed order, thanks
sunrisefordparts
thanks for answering your own questions :thumbup: thanks for the order bud.
RSK
Connecticut
could I have a price for a harley davidson grille for a 2010 f350 in primer so it can be painted shipped to 06043. Thanks!
ken6881
I am needing ford head gaskets for a 05 6.0 Powerstroke. How much?
sunrisefordparts
the grille come from ford already painted either blue or black list $1089.40 sell $784.37 shipped q#315194
sunrisefordparts
head gasket kit list $197.94 each sell $154.39 would just need to know opon ordering if you have 18mm or 20mm dowels. free shipping q#315196
