Dash Daq boost readings
WoodBoy
Alabama
I have a mechanical gauge on my truck and it always reads the same as my LW does.
Are you datalogging Eric? Or have the alarm set at a specific that once it comes on you look at your mechanical? Please tell me your LW is not reading PSI on the backpressure
SEABEE08FX4
Montgomery TX
No I'm no datalogging it, just watching both as I have them set up pretty close to eachother. I'm referring to boost pressure though, how ever I do wish the BP was shown in psi instead of kpa.
WoodBoy
Alabama
Yeah me too.. I just set my alarm and wait for it to go off and i know where i am above then LOL
im wondering if there are certain ford flashes this is more common on, or strategys that may or may not make a difference.
can someone hook shop air to the map sensor and regulate the pressure to higher than 60 psi controlably? I would be interested to see if everyones stops reading at 60 psi like the few i have seen here
WoodBoy
Alabama
Im about to go plug the end of my exhaust and put an Air pressure gauge in one bung hole while i use the shop hole to blow air and pressurize through another bung hole.. Ill let you know shortly
SEABEE08FX4
Montgomery TX
Humm I don't know about that but I'll wait and see.
