Swagger Build thread
rat49f6
Vernon,NJ
Between them and petey going wild with the grinder it looks so good
Sent from my SGH-M919 using Xparent Green Tapatalk 2
rat49f6
Vernon,NJ
Put in a few hours on the air management today
Valves are mounted and plumbed to the tank... minus 1
Need to grab a few more fittimg before I can make it 100%
Dont think I posted pics up so here are a few of the newly clearanced radiator mounted up
rat49f6
Vernon,NJ
Also took a lil teaser pic of the bumper mounted ... needs a lil trimming via asphalt because its hold the truck off the ground in the front
rat49f6
Vernon,NJ
I dont see why this wouldn't work with any suspension height
rat49f6
Vernon,NJ
Some pic updates for everyone
Valves mounted under the bed
Pile of tape off the first harness I took apart...not shown is over 100 feet of wire we removed
Reinforced the cab floor with 1/2" square tube
rat49f6
Vernon,NJ
Had to make some room in the shop for my other project but still making progress on both
Finally removed the last 4 factory tight bolts
Cab floor is 100% welded in just need to grind and paint before moving on to the same on the frame
rat49f6
Vernon,NJ
Managed to get the cab floor covered with some diy raptor liner ...
Tomorrow I'm pulling the bed and welding up what needs to be finished on the frame so I can paint that
rat49f6
Vernon,NJ
I need to play with it a bit more before I use it some where where it will be seen but yeah it lays down great. .. not as thick as a body shop product but way better than products like huculiner
JMart
DFW
Thanks, I may be doing it on some projects this summer is why I was asking. Thanks for the heads up on the playing with it. I will start out under the truck for sure then.
rat49f6
Vernon,NJ
They also make a tintable version to color match anything
JMart
DFW
Yeah I was thinking about doing that and tinting it black just to make sure it takes longer to fade. LOL
rat49f6
Vernon,NJ
Wired the valves into a 10 terminal junction box ... valves are wired into the box and the 9 wire cable is wired in now to just connect the cable to the switch box
Tomorrow the rest of the air line fittings should be in and I'll be able to plum the valves in 100%
