Steering stabilizers
NotStock
Tucson, AZ
Our kit will not be a direct bolt up with the MagHytec cover, you will need to clearance around the two bolt heads and side slightly. We have kept that area as clear as possible to keep the trimming as minimal as possible. Our dual steering stabilizer will not limit travel what so ever. Full lock to lock steering is maintained. Compared to the OUO, there is nothing to compare. Thats an apples to oranges, $300 kit compared to whatever they charge for that. I also wouldnt use a hydraulic assist cylinder with any stabilizer setup designed for a simple stabilizer shock. The ram exerts MUCH more force and would end up bending or damaging something. Hydraulic assist doesnt really become needed or IMO make an improvement on trucks running smaller than 37" tires.
