20x12 on stock height trucks
swinky
Eastern, Nc
My 03 4x4 stock height in front clears 20x12 -51s by about an inch.
Sent from my HTC One using Tapatalk
big john
southern indiana
Your going to need more lift then just a leveling kit. A 2wd with a leveling kit is going to sit lower than a stock height 4wd. And on a 4wd you need a leveling kit with quite a bit of trimming to fender and bumper.
It's not going to clear without a lot of cutting bubba.
thanks man. if I put a 4" lift could I run go ahead and run 35x13.5s instead of the 33s and be good to clear with no trimming
SEABEE08FX4
Montgomery TX
If you guys think your going to run 20x14's on a pre 08 truck with just a leveling kit you're in for a surprise. I had that same size wheel on my 08 with 34's and a 6" and it still rubbed.
HOOV3R
Central PA
WHS. For me to clear my 22x12s and 325/50s with just a leveling kit, my fenders had to be trimmed a lot to allow turning without rubbing.
swinky
Eastern, Nc
Don't forget the 99-04 trucks are quite a bit narrower.
swinky
Eastern, Nc
swinky
Eastern, Nc
They are axle wise, but they also have a smaller fender opening. And leafs that are in the way where coils are not.
True. But a wheel with that high of an offset should never have issues hitting the leaf I wouldn't think.
HobbyStock62
Mpls, MN
has anyone done the 20x12s with 420s' on a leaf spring front? wondering how i can lower the front a couple of inches if i take the block out of the rear to make it look right.
swinky
Eastern, Nc
Mine sits dead level. No block rear and stock front.
johnp115
Southern MD/Charlotte NC
That looks great man, what's the specs?
Sent from a Cummins plant, driving a Powerstroke, with a TDI on the side!
Thanks, the truck is leveled out and lowered just a tad. Sitting on 20x12 -44m fuel hostages. 305/55/20 terra grapplers. Minor stretch to the tire. Slight rubbing at low speeds making sharp turns with body roll. Gotta let it rub for a couple days so i can see exactly where its rubbing and cut accordingly.
JrStroker
Ahead of the competition
Leveled out and lowed a tad? Elaborate.
Cory Anderson
johnp115
Cory Anderson
Bought the truck like that so its the best i can explain it, Better than saying stock setup, and misleading someone.
Best i say is its lowered around an inch. 5200 coils in the front then lowered/leveled accordingly in the rear.. On bilstein shocks.
bft blue oval boys
Burlington, NC
Looks to be, like you said, a little lower than stock height. Maybe 4800 Springs and no rear block. The pic I posted a couple pages back is stock height in the front and 1" block in the rear with the same size tires and they look way smaller on my truck lol.
