My personal compound build
Cromwell, CT
SunCoast billet flex plate came in the other day got that all installed
That same night dropped the motor in and connected her to the rest of the drive line
started messing around with putting the RCD tubed manis on for mock up of the turbos
this might have been the pic morgan was talking about earlier with some fittings in the oil rails :poke:
Idiesel
This is going together very nice, Good work! Love the manifolds and very excited to see the hpods
Cromwell, CT
It's kinda an elite/hpods/my own design dual pump kit
i may have missed this somewhere, but what size turbo(s) and injectors u planning on??
And there 305cc/150% RCD hybrids and as of right now going to be running a S467.7 FWM as a high pressure and a S591 for a low pressure charger
MorganY
college station, tx
I'm modifying the HPODs as well. Machining it differently. What do you think about those SS hydraulic hoses?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Idiesel
Machining it for better flow at the block? Or what?
Cromwell, CT
hmmm intresting.. and i think they look nice on my comp screen never seen them in person but they seem to get the job done
i think he's talking machining as in... morgan correct me if I'm wrong... but if i had to guess he is going to machine into to the back side of the block another port to plum in another pump of some sorts
Idiesel
Oh okay, I haven't seen too many dual pumps in pictures much less in person so I'm interested
ford rules
I have the complete HPODS on my truck and the SS hoses are nice quality. Haven't had a issue yet though the kit has only been on for about a month.
Eventually I want to feed the distribution block with another pump like I believe you and Morgan are referring to.
Idiesel
Was the hpods worth it or do you feel just jumping into a secondary pump would have been better?
ford rules
I really couldnt say since im still stock injectors, it seams stronger on the bottom end now though.
6 L chevy eater
Franklin, VA
Awsome selection !!! It should be pretty nasty when u get it all buttoned up!! Everything looks top notch ! Keep it up.. Should make a around or over 100psi I would think!:D
Can't wait to see final product
ford rules
Maybe I spoke to soon, got to school and noticed I blew a o-ring on the fitting feeding the pass head, luckily I had a spare!!
Cromwell, CT
haha yeah we didn't wana jump too high in the fuel could have gone 345 or 325's but figured we could leave some room for motte fuel if needed, and yeah i hope that amount of air can clean them up nicely and if not I'm sure spray will lol
that blows, and yeah its more of an elite set up to be honest its slowly coming together finding bits and pieces each day
MorganY
college station, tx
Correct sir. Sorry, I thought you bought the entire HPODs.
Did Bob just sell you the fittings?
6 L chevy eater
Franklin, VA
Yea spray works wonders and makes good power, but my stock bottom end didn't like it at all . Lol. Looks like you've got that cover though!
Chargers should work well with those injectors. A dyno tuning session will be worth its money for your set up IMO .
Cromwell, CT
well yes and no, i got everything but the lines i guess you could say but its the new style system, kinda wish it was the old style honestly
haha yeah figured save then sorry later u know, plus everyone around be involved with this pushed me to just build it and do it correct no bs
Cromwell, CT
Got a lot of updating to do here like damn lol
got the RCD RELO kit all mounted up, a little farther back on the frame then its suposto be but wanted to leave room for a coolant filter and other stuff up front
also started to play with this set up lol
did a little machine work to gain access to the test port under the turbo pedestal
