1.5" wheel spacers 8x170
1sicpsd
waterford wi
i have a new pair of 8x170 wheel spacers had them on the truck for a few weeks. decided to go with the 2" ones instead. the company i bought them from won't return them for thicker ones. looking to get what i paid $200. contact me 414-530-3589. thanks
thread pitch is different depending on year.
You do know that you use your own lugnuts for the stock studs and that the spacers come with their own matching lugnuts for the studs that come out of the spacer right? So there will be a total of 16 lugnuts in use on each corner....
i see.
when i did my wheel spacers, i had to use the counterbore lugs that came with the spacers to hold it to the axle as my truck is a lariat and had aluminum wheels so the stock, flat faced lugs wouldnt work. of course i cant see a pic of what the OP is selling so i'm not too confident but yes, i do know that 16 lugs are used at each corner please.
i also know that there are two different thread pitches on super duties.
i see.
Yuppers..
1sicpsd
waterford wi
Yes they come with that style nut u use to hold on the spacer and use ur factory ones to hold on the rim to the spacer
