sunrisefordparts
Front and rear paintable bumpers for 08 superduty with the black plastic molding for both. The rear has the back up sensors. And driver and passenger front inner fenders for same truck. Thank you
heres your quote.
  • q321612.pdf
sunrisefordparts
Okay just sent payment thanks
ford_trck
Vail, AZ
sunrisefordparts
Can i get a quote for my pile of parts please? Thanks
Front leaf front bolt (2)...........w704660-5426
front leaf front nut (2).............n807659-s427
front leaf rear shackle bolt (2)..w500593-s439 these should be leaf to shackle
front leaf rear shackle nut (2)...n800237-s301
x code front springs (2)............2c3z-5310-af
front super duty u bolts (4).......f81z-5705-za
socket (2)...............................f81z-13411-ba
pigtail (2)................................1u2z-14s411-bea
shifter knob for a 6 spd manual
08+ tail lights (2)
cab lights and harness for a 2000 SD
bottom of door weather stripping for a 2000 crew cab all four doors
ups tracking #s 1Z5775X90397091316, 1Z5775X90398821703, 1Z5775X90395134498
ToMang07
Mainah!
How much for a set of bed bolts/strap nuts for an 02 CCSB?
Anything else needed for a new bed install? (Need all new hardware.)
all bolts and nuts plus it shows shims at front of bed behind cab total shipped $81.22 not sure if you could use your old shims or if you need more, i priced only 2 q#311876
Payment Sent!
thank you bud.
So the box of bed bolts you guys sent only had 6 bolts/nuts in it. There's supposed to be 8.
CoreyMS
Can you get just the leather arm rest part for the door panel, drive side, 2012 F250 King Ranch
