imelmo
- Joined
- May 18, 2011
- Messages
- 6,635
- Reaction score
- 2
The rendering looks great. I have wanted to find a RC for awhile. and do something similar but with a 4x4.
Question - Are going to extended the wells in the bed to fit some wider tires or just go with a different offset wheel in the rear for the wider tires?
How much power/ torque are you planning on making arnt you worried about making week spots in the frame by cutting it
---Clayton
2002 eclb 7.3- for sale
1990 Chevy K1500- for sale
race truck- in the works
2003 Subaru wrx wagon- new dd toy
sent from the sh!tter withTapatalk2
From your rendering it looks like a 22x12 with a 325mm width nitto 420 should be wide enough. I have 305 nitto 420's and they just about 1' wide. Quite a bit of contact area.
Nice build man that's gonna be a fun truck when your done
The front spring hanger will be welded right over the joint and bolted on either side. Then the frame will be boxed inside spanning the joint. That area will be as strong or stronger than an uncut section of frame.But I see your concern, nevertheless.
Shooting for 625-650whp on fuel and 700+ on spray. Mild motor build, all things considered.
Humm good idea and thanks for the info. This could be the baddest rcsb yet good luck man
Don't think I will get a 12 under the rear but haven't done final measuring yet. Thinking 10.5 right now because I'm tucking them. Staying with 20" wheels because I want a decent sidewall on the tire.![]()
