Up against the wall engine tap
JuststrokeIT
Truck doesn't get drove much and for past 6 months has sat put in a new BTS last night get it all buttoned up and go on a test drive get the truck up to speed and around 60mph it starts a low tapping sound out of the engine let out off the throttle and it goes away. I'm guessing I have a lifter go bad but is there something I may have missed?
JuststrokeIT
Truck does seem down on power and runs roughy after it does it but then will smooh out and run okay again. And smokes like a freight train maybe worse. I'm wondering could algae or somethin like that on the fuel even cause somethin like this
JuststrokeIT
I don't know it's not that loud so you may not be able to hear it over the truck on my phone but I'll try and take one tonight when I get off work
TARM
Any codes? Have you run a contribution test?
Could be something as simple as UVCH a dead or broken injector something with a cylinder etc... I would not be running it until you figure it out.
Drdiesel27
hello i just bought a 1996 ford f250 7.3 and i wanted to ask you if you recommend me putting a chip on my truck i really would like to put one but i don't wanna ruin or break something on my truck please let me know your opinion by private message thanks _Gabe
JuststrokeIT
what kind of addative? I drained the fuel out of the tank it was very dark brown and added in some Case IH anti alage stuff I got at the dealership for storing our tractors
runs a little bit better but still has the tap/mis to it thou at upper rpms im hoping maybe running it will work it out
