RNicol
Just got a call from my dad, and our farm truck which is an 01 F-350 7.3 will crank good but will not start... I'm not home to look at it right now but I was just wondering what you guys think
First of all, check the batteries. Second, we need more info than "It cranks but won't start".
unless he parked on a grade or ran it for a long period before shutting it off.
here in the rust belt lately I have been seeing ebp tubes rusting out and in return the tube gets extremely hot and melts the cps wiring
had one 2 days ago that the other stealership was pushing for a new pcm and said my chip fried it. they wanted $1275. he called me and said "hard to believe the chip did that after 7 years" he had it towed in, chip and computer bench tested good. it got a cps pigtail and ebp tube. truck runs perfect again
True but if you're at "that point" with engine oil it will sputter and then die, sputter and die, then it'll run and die only to not restart.
