D66stroke
Trying to help my grandfather fix a problem that has come and go, but now a permanent issue. The trucks running lights, fog lights, and blinkers work how they should. The high beams work when you hold the blinker/high beam selector back but not in the locked forward position, and no low beams at all. He replaced the switch and fuses without any luck. I used to flip the switch back and forth as well as the high beams to get the low beams to work but that no longer does the trick
