7.3powerstroke00
03 6.0 f350 still has egr cooler in tact, engine has around 130k miles, truck came in with bad bearings in rear end, ball joints, and said it had a surge to it at about 45-55 mph. Rebuilt rear end, replaced ball joints on driver side and went for test drive. It would barely get out of its own way, acted like it was starving for fuel. Also noticed when in park it started studdering/missing at about 1200 and tops out at 2500. Changed fuel filters and checked fuel pressure, it was at 32-34 psi. Picked up the blue spring kit for the regulator and installed it, now fuel pressure is at 60-64 psi. Still runs like crap and still won't rev over 2500, and progressively gotten worse along with slow startup. Not a long crank, just took a second to pick up and run. Had a small oil leak and the icp sensor was cracked and leaking. While I was there I pulled the ipr to check the screen, it was clean and good. Reinstalled ipr and pressure tested system with air for leaks, couldn't hear anything even after a good 15 min. Reinstalled icp and fired it up, killed it and it busted right off like normal but still will not go over 2500 rpm and acting like it's starving for fuel. Only code was for egr insufficient flow. It has a few injectors that vary from 0 to -4 and a couple that vary from 0 to 4 on the cylinder contribution test. Turbo vanes are cycling because you can hear it through exhaust. I pulled the map sensor tube from intake to check if it was stopped up. And checked ebp tube and sensor, they were clean. When you pull up the data it says n/a on the ebp pressure and voltage. If you put it in gear and stall it it won't even get over 1200 rpm. I'm sure I've missed something but maybe somebody here has some input without throwing parts at it.... I'm stumped and even a couple other guys I know that have been working on 6.0s several years aren't sure what's going on....
