RBernardi
2003 drw 2wd auto. Co-workers truck says it WILL Only start when spraying ether into. Suggestions anyone (besides not spraying the ether)
Scan for codes. It could be an ICP issue, do you have any way to monitor ICP psi when cranking? Needs to see 500 psi to fire.
Lots of miles?
Pull the oil filter and cap. See if the oil level rises when someone cranks engine over. If not, low pressure oil pump is trashed
Bet the HPOP is weak or wasted based on the miles if it is original.
