05+ axle conversion parts
rpm-inc
rpm-inc
Are you talking about where the bottom of the springs sit on the axle that is removed with one big bolt? I may not be using those with my conversion. Thinking about coilover.
DZL JIM
North East Ohio
I'm looking to do a coil conversion on an OBS, so I also need the cups the springs sit in.
It's been a while since I looked under a truck with that style suspension so I don't recall specific details. If the cup just bolts on or welds on, I don't know how it all gets fastened.
Also, you have the bracket for the track bar I'm guessing that attaches to the cross member. What does the other end of the track bar connect to? A bracket on the axle?
Thanks.
rpm-inc
Are you going to use an 05+ axle? Where the bottom of the spring sits will probably still be on the axle. Yes the other end of trackbar goes to a ball joint on the axle.
DZL JIM
North East Ohio
No, I was hoping to re-use my axles and add the parts needed to it.
Looks like more trouble than it's worth, I guess I'll pass. Thanks anyway.
