+'05 axle conversion
gnxtc2
Bergen County, NJ USA
Currently have a 3" Sky RSK. I want to lower my truck to increase clearance over the bed for the GN trailer. If I convert to +'05 axles, would the height go down if I use stock coil springs?
Does the coil sprung front end ride better?
Thanks
Billy T.
gnxtc2@aol.com
equalizier
I have a bigger lift and wheels and I can tow a goose neck trailer.The neck on my trailer is adjustable.I don't know what kind of trailer you have but it would be worth looking into.
FrankTheTank
Cecil County, MD
It would be the same or around the same as a stock 350 truck. You can also buy the 4400lb gas truck coils (prolly closer to actual front weight anyway) to drop it even a few more inches. The front axle weight on my truck is 4800 and rear is 2400 as it sits on level ground for a referance
You still got my number? I can throw a few measurements at you
Jason
Somewhere down in Texas..
The OP is pulling an enclosed gooseneck. When I had my lifted ccsb, I played hell getting one built with the riser height to clear my 6" lift and 35's. NOBODY would give me the riser height AND a tapered nose. Sometimes it's just more sensible to go lower...like I did.
Tom S
Thanks
Billy T.
gnxtc2@aol.com
The 6.4 truck I have driven on concrete highways seemed to ride a bit bit worse then my truck does with the current setup.
kmanxj
Reed City, MI
I think it would sit lower. I am running all stock 06 springs and I clear 315's but they are tight in the front. It is definitely the same height or shorter than a newer one ton truck.
Strokersace
Towanda, KS
I'm running 4800lb coils and F250 2" rear blocks. Rear sits about 1.25" higher than front, so very little rake. Ride is amazing and overall height is lower than a stock F350. I wouldn't go any larger than a 33" tall tire on my setup. Towing clearance is awesome with this setup. Coming from a 4" lift with F350 rear blocks, I gained 5-6" of clearance for goosenecks.
Personally, I don't know if the 4400lb springs would give enough clearance between frame and axle. It'd be tight. I don't have bump stops installed but if I did, I'd only be a couple inches off them with my 4800's.
Billy if you want pictures, pm me your number. Or I can email them to you.
kmanxj
Reed City, MI
Which springs are which? Mine came from an f250 with the 6.0.
I have the 2" block in the back and mine sits about 1/4" higher in the front. I plan on an F350 rear block to get some rake back.
TyCorr
The front springs on the diesels should be the same. The rear block is different.
Strokersace
Towanda, KS
I bet you have 5600's. The true way to tell is the code off the door sticker of the donor vehicle. If not available, then there might be a part # tag on the coil itself. Otherwise, I'm not sure.
TyCorr
So the front coils arent the same? Or are you saying he might have coils off something other than a diesel donor truck?
Strokersace
Towanda, KS
Coils have different rates just the same as leaf springs. And they vary on diesels and on gassers. The typical ones I've seen on diesels is 5600 and 6200lb rates, however some came with 4800's. My 4800's came off a factory 2011 diesel. But the 4800's and 4400's are typically found on the gassers.
morefuel
Chico, California
I believe I have the 4400's. At least i told them I wanted front springs from a 5.4 gasser. The front rides quite nice. You do want to be careful about what bumps you hit or how fast you hit them. I have no bumpstops and I think i've only bottomed it out once when i didn't realize how aggressive of a bump it was. With bumpstops it would be perfect.
Strokersace
Towanda, KS
On your 97? Any pics? What rear blocks, if any? I'm curious of ride height compared to mine. I spent quite a bit of time out in Chico this last summer and fall.
Strokersace
Towanda, KS
Mine with 33x13.50s with -24 offset:
Same rims with 33x11.5s:
Pulling a load with no rear airbags, SD B-code rear springs, and velvet ride shackles:
Current setup with stock 2010 18" wheels and 33x11.5 tires. Airbags installed.
Can get better current pics soon.
FrankTheTank
Cecil County, MD
4800 lb coils came in the super cab short beds, and STD cabs with a diesel. Also depended on towing package, plow package, 250, 350, but yes.... lots of different spring rates.
Anyway, there should be a tag on the spring itself you can cross referance to a spring rate
