05+ axles in obs
lildiup
Hey I put 05+ axles in my 96, was wondering do I have to change the brake pro prop valve for the rear discs to work right?
rusty1161
Whittier, CA
The OBS F-Superduty had rear disks and hydroboost instead of a vacuum booster. The master cylinder has a different valve than the drum brake master had. Let me try and link the thread.
Rusty
rusty1161
Whittier, CA
If you keep your original master cylinder, you j ust need to swap valves. If you go hydroboost with an F-Superduty mastercylinder, it should come with it.
Rusty
Got4wd
You can also get them off of a old f150 bronco. 93-94 ish. It's the same one as the fsuperduty
lildiup
97 f-super duty? I can just get a new one from ford right? So I don't need to change the prop valve
