rowekmr
Here is a 2005 F350 Lariat crew cab, long bed, dual rear wheels 4x4 with the 6.0L power stroke diesel engine. This truck is a southern truck (GA) been down south its whole life up to a few months ago when I bought it so there is none of the typical body/frame rust of Midwestern vehicles. Being a Lariat it has heated/powered leather seats, 6 CD in dash CD changer, climate control, steering wheel controls for radio and HVAC, electronic 4x4 (on dash), rear back up sensors, keyless entry, cab clearance lights. All options work (AC blows cold) except drivers heated seat.
Truck has a few scratches typical of its age and clear coat is peeling on one side of the top of the box. Recent work (done at dealership) incl new thermostat and coolant flush, new passenger drag link and tie rod end, new trailer brake controller (in dash), vacuum solenoid for 4x4. The engine has fresh T6 synthetic oil and new OEM oil/fuel filters. This truck has gooseneck ball in bed and rails mounted for 5th wheel. I drove this truck for 3K as my daily driver until I didn't need it to tow.
Recent Issues with truck: Recently started to smoke Ford diagnosed 4 injectors bad and cracked bellows so it will need up pipes also.
Since I had it degas bottle has crack in it. Power steering hose has slight leak in it also and tires need replacement.
Truck runs and drives just smokey when you get on it.
Asking 9K any questions contact Joe at 773 879 zero681 or rowekmr(at) aol.com
Thanks for looking!
Slideshow of pics:
http://s817.photobucket.com/user/rowekmr/slideshow/2005 Ford F350 Lariat CC DRW
Thanks for looking!
Slideshow of pics:
